Hopefully you ordered an IC60 to integrate with your EasyTouch. Having a 22,000 gallon pool in Tucson, an IC40 is going to have to run more than 12 hours per day to provide the necessary chlorine.
It is recommended to dose for CYA 70 with a SWG. Some members in the desert southwest choose a CYA of 80.
Be sure to test your pool water salt level BEFORE adding additional salt. Adding liquid or solid forms of chlorine and adding MA all adds salt to the water. Given that you drained/refilled 3 weeks ago, it's probably minimal.
What test kit are you using? Add it to your signature. Also suggest you get a K1766 salt test kit if you don't already have a drop test based salt test kit.
Update your signature with model numbers for your equipment and test kit info.
This assists us when providing you help.
