Hi all,
A good friend is filling his pool with relatively clean water from a stream to avoid using his shallow well. The water is going through a 50 micron filter before going into the pool.
I felt once it's full he should get his FC up to 12ppm and start adding CYA. He's going to get me a pH reading tonight.
But considering the source I wanted opinions. Should he go higher? He'll be using 73% cal-hypo initially.
