Howdy neighbor... I get the that draining the pool is not cost effective, I am in the same market. I think you can limp along until you get to the winter rains that will dilute your pool anyway. You didn't mention what temp your pool is at in your initial post. The warmer the water the harder it is to control any algae. Luckily the temp is going to start dropping in the Sac area into the more pleasant Indian Summer temps.
I like the suggestion made to see if you can do a SLAM to completion with your current CYA. It wouldn't hurt to kill off all your algae before the winter kicks in. And just keep brushing. you will likely end up with some discoloration or roughened areas of plaster even after the black algae is gone. I noticed my local Walmart has LC on sale.. likely due to the end of the pool season.
Also fill in your equipment specs in your signature. It helps us figure out what you need. for example if you are running a SWG, then you only need to get to the 60-80 CYA range.
Hello back! Sorry to hear you're in the same "if you want more water, give me your firstborn, along with an arm and a leg" market! My pool temp is about 85, no heater. As of this morning, algae has retreated an incredible amount, indeed leaving behind rough patches of plaster and remnants in those pores, which I have been repeatedly brushing over, and am watching very carefully. The only slimy stuff left as of this morning, were small patches I missed in the grout lines of the tile here and there in my initial and previous brushings. And, I can see just how the slimy layer protects the algae; the tiny patches I missed look like prime algae specimens, whereas the bigger patches that I brushed correctly are all disintegrating. I took care of those tiny patches though, this morning.
I originally thought I might monitor this progress carefully, and at the first sign of slowed progress, SLAM it. I am not scared of the SLAM process; in fact, it sounds darned easy. Nor am I afraid of the cost of the LC, compared to the cost of water where I am. In fact, since my pool appears to increase by approximately 2.5ppm per gallon of 6%, if I use the Walmart bleach that's only $36 to get to 39 FC from where I am now, and because right now my pool seems to drop 2.5 over 24 hours, if I have to add 1 gallon every day for a week that's only another $21, and that's only if I NEED to go an entire week. I'm just the type of person that doesn't like to use more chemicals than absolutely necessary, if I don't have to. That said, if everyone says I, without a doubt, will aboslutely need to SLAM at 39, SLAM I will. I just want to be sure I've given myself enough opportunity to hear from someone who says less worked for them. For what it's worth, I have seen pools with much, MUCH more black algae than I have had, if that matters. And, if I had it like the ones I saw, I would SLAM without hesitation. The amount I have had come back every summer I could live with. But, I noticed that in the past few seasons, it's been getting worse, and can see that if I didn't do something differently, I would eventually end up with one of those horror stories, which I don't want to happen.
Oh, and I could've sworn I filled out my pool stats, perhaps I didn't put it in the right place. I did have trouble after registering, and got banned from the site right out of the gate due to some kind of bug. Perhaps that had something to do with it. I will go enter it again.
