I was told that I need to inspect and clean my cell with 20% muriatic acid and 80% water solution after every 500 hours of use. And that my salt system will have a inspect cell warning light pop up. My pump runs 24/7 from April to October. So this way, I hit 500 hours just after 20 days. So should I only run the chlorinator for 8 hours a day but at a higher chlorine percentage or 24 hours a day at a lower chlorine percentage. I'm not sure if the chlorinator can be put on a timer, I'll have to check on that.
