Is there any good rule of thumb on how long to run the filters a day? The default setting on mine is 8 hours a day, 4 hours in the morning from 10-2 and then again at 10pm-2am.
I realize it makes a difference how much the tub is used. Ours gets used maybe once a day, one person for 30minutes. Some days we do not use it at all.
I find that my Ph level is hard to control. I test every morning and it is almost always at 8.0 or slightly above. I then add acid to get it down to around 7.2-7.4, but by the next morning it’s back up again.
My TA is always low too. Usually about 30-40, I add enough soda to get it up to around 50. By the next morning it’s down to 30 again.
Maybe the pump/jets running 8 hours a day (constant aeration) is causing problems?
