- Apr 10, 2018
- 6,323
- Plaster
- CircuPool RJ-45 Plus
It can be a little challenging. I have the same filter, so I can tell you how I do it.I cannot get the strap back on. The top half of the case wouldn't seat on the o-ring.
Before reassembly, make sure the bottom manifold o-ring is properly seated. Make sure you put the air relief screen on the center pipe before reinstalling the upper manifold. This is a common area for leaks if not installed properly.
Before installing the top half, make sure all parts are clean. I use a little bit of dish soap on the O-ring/seal and put it in place. The top half won't automatically drop into position. You'll have to install the band clamp and begin to tighten it. As you do, use a rubber mallet and tap the band clamp around the perimeter of the filter as you tighten the nut. Continue to do this several times until the spring on the band clamp nut is compressed.
