I wanted to get some of the electrical work out of the way while waiting for pool instal.
How is this looking?
-100amp sub panel
-1” schedule 40 conduit (filled to 39.7% capacity). 20’ run.
-#3 thhn for hot1, hot2, and neutral, #6 ground
-Neutral and ground bus separated at sub
-Box bonded to 8’ copper clad grounding rod on #6 bare copper.
-50 amp 240v (heat pump), 20 amp 240 volt (pump and salt water chlorine generator), and 15 amp 120v (light and aux outlet) gfci breakers.
-100amp sub panel
