How important is draining pool water level?
Thanks. I poured some water into it and it never overflowed so must not be capped. Didn't see it go anywhere in particular so perhaps it's just draining under the surface?
That would not be good.
Shove a garden hose down it and let it run for a few minutes. Look for water somewhere. Or look down with a flashlight. If it does just end under your decking that bad and it should be capped off. Last thing you want is water under your deck.
This is the pipe we were told is the overflow outlet
Here you can see the outlet in relation to the deck, where the skimmer is and where the overflow is located at the pool. The skimmer is the closer lid in the picture.
The random piece of pvc sticking up out of the ground is what they decided to leave in case we wanted to hook up an overflow. I have no idea how that could even happen as we have no water source or sprinkler system in the yard.
This is our over flow. Pool miser?
With lid off. I am facing the direction of where the outlet pipe leads. Looking at this picture, the pool is to my right (west)
Inside. These are located to the east
Inside bottom. Lots of sediment and some chunky debris
A close up.
I had called to tell them I didn't think it was working as I had found the float equipment inside the well in a bag. They sent out a very nice older gentleman who took the bag out, said we didn't need it unless we added an aitofill. He spent some time cleaning dirt out of the pipe with a shop vac and declared we were good to go.
He told me to periodically open the lid and use a stick or something to create some turbulence to keep it clear of dirt. Even with creating turbulence, I have never seen water come out that pipe.
Hubby tried to snake it a a few weeks back and had a hard time getting the snake out. It got snagged (we think) on a bend or elbow waaay in there.
I've not ever opened the drain plug as the base of my filter either. Currently don't have an ideal place to redirect water. It will flow to my neighbor's house. Was considering adding gravel around edge of equipment pad to create some sort of drainage for condensation from heater at least.
I have a similar filter (CCP420), and I was able to rig up a valve and hose attachment to replace the drain plug -- useful for draining rain fill as well as cleaning the filter without making a huge mess all over the pad.
I'll get the sizes later and post pictures to a new thread -- it's a bit tricky because the drain plug is in a confined space facing down, but I believe I ended up with a PVC 1.25"->3/4" reducer, a 3/4" street elbow, a 3/4" ball valve, and a hose thread adapter all from my local ACE hardware. Simply screwed it together and it works like a charm. Perhaps not as fast as an unrestricted 1.5" pipe or something, but I can drain off 2-3" in about 20 minutes, which is fine and faster than the crappy submersible pump I lugged out last year.
Hello MIles,
We have an auto-fill system, but our drain system is separate. It is a port located in the back of one of our skimmer housings.
The port is connected to a piece of pvc that ran under the decking and to a lawn drain. (It actually ties into the drain line for our deck drain.
I would check your skimmers and see if there is a hole inside them above the waterline. If there is, you can quickly stick a wire or stick inside it to see if it is functional or not. If it's not the stick will stop immediately.
