How do you get your chlorine out of the bucket?
trivetman
817
Jenkintown, PA
Hayward Aqua Rite (T-15)
Total noob question - whats the best way to get chlorine out of a large 5 gallon bucket? I've been buying 12.5% chlorine from the pool store which is available in 2.5 or 5 gallon tubs, both of which are too heavy and awkward to lift and pour. To measure out the 50 or 60 ounces I use each day I've been using a plastic bilge pump I found in the garage which I am sure will break any day from the chlorine exposure. I plan on hooking up a stenner next summer but for now it is all manual. Any suggestions as to the best way to do this when my bilge pump breaks?
Safety Siphon - Safe Multi-Purpose Self Priming Pump https://www.amazon.com/dp/B000BG1X54/ref=cm_sw_r_cp_api_lw-MzbWB3F4MF
To empty my 5 gallon carboys into the stenner tank, I use one of these shake siphons.
For your situation, I wonder if emptying car boys into 10 gallon water jug with a spout would do the trick (clearly marked with the words BLEACH to prevent any disastrous beverage selection mistakes)
Igloo 10 Gallon Seat Top Beverage dispenser with spigot and Cup Dispenser https://www.amazon.com/dp/B000F6SHTK/ref=cm_sw_r_cp_api_kz-MzbTBD4XPJ
Or maybe a spout cap on the carboy to avoid the transfer all together.
Thanks. Ideas much appreciated. You guys on this site have been incredibly helpful to this new pool owner on more than one occasion now.
Quick follow up on this post. I recently tried a new siphon system (used copper safety siphons on vinyl tube for the past year.)
I’m fairly pleased with my first use of this unit. I cut the draw pipe down to size. It easily starts the siphon with the pump on top, and the pump helps suck out all but the last few drops from the carboy. I bought 1 for $24 but it looks like you can get 2 for $32 on amazon.
I like this solution better than the safety siphons because the copper head keeps corroding from the bleach and losing flecks into the Stenner tank. Those flecks end up getting sucked into the pump and into the pool where they stain and have to be acid burned off the plaster. This unit is all plastic.
2 PK TERAPUMP TRDRUM30 TRTI901 Extra Heavy duty Siphon Drum Hand Pump https://www.amazon.com/dp/B079J7XD9N/ref=cm_sw_r_cp_api_HvlBBbMXN78RF
