- Jul 21, 2013
- 65,126
- Plaster
- Pentair Intellichlor IC-60
And no, the timer is inside and the SWG generator is outside.
For many safety reasons the code requires and you should have a shutoff outside near the pump. Usually that is either a nearby CB or timer switch.
You should run wire from CB panel inside to timer outside. That wire needs to run outside wall up to timer so needs to be THWN in conduit. Then wire in conduit from timer to pump and mount SWG power center next to timer and wire in conduit from timer to power center.
