Our current cya level is 80. We already did a big drain this season and are on well so I am going to let it go down naturally over the summer. How do I know if a chemical has stabilizer in it? I have some chemicals from last year that I would like to use up as long as they are not going to add stabilizer and obviously only if I need them.
Bio guard lo'n slo (ph and alkalinity reducer)
Bio guard Algae all 60 (not sure if I will use this, but we currently have a lot of organic material going in the pool from gyspy moths)
Bio guard sparkle up (removes copper so no need right now)
Bio guard balance pak 100 (alkalinity increase (no need right now. I need mine to go down some more)
Refresh + (shock)
Also, do I have my gallons of water estimated incorrect? I added the amount of liquid chlorine that was suggested in the app and it didn't raise my chlorine levels much. I was supposed to be going from 4.5 to 9 and it only went to 6.5. I am using 12.5% and the expiration date isn't until 2025. I tested the chlorine a hour after adding and again this moring and it was the same.
24' round with 52" sides. We have a ledge (approximately 1 ft wide it is uneven from some of the sand collapsing when we filled the pool. The company sold us play sand instead of pool sand) around the perimeter, the ledge is larger in one area to accommodate steps, and dug the rest down about 8" . I have it estimated at 14,000 gallons.
Refresh + (shock)
