How do I install my new pump?
nostaljake
73
Bethesda, MD
My pump kicked the can last week, so I have a new Calimar pump on the way (1.5 HP since the 3 HP is out of stock). However, I'm new to this whole pool ownership game, and it seems the previous stewards of the equipment pad didn't leave me with a lot to work with. See attached photos! You can see the area right before the pump is a mess with some kind of puddy or something.
Where should I even cut to begin working? I marked the only spot that comes to mind for me, but I don't know if there's enough space to install a new coupling there. How much room do you need? Or should I start somewhere else?
That looks to be a 1.5" check valve. If you want to keep it, break some of the epoxy off you will see the black portion of the valve body toward the pump. Cut the pipe as flush with that as you can. Clean the valve body and install a 2" coupler over that port and go from there.
Sweet, thanks! Is it safe to use acetone or alcohol to help remove the epoxy and clean up the check valve?
So If I'm understanding the plan, I would be going like this: check valve --> 2" coupler --> 2" PVC --> union --> pump. I'm a little concerned about running out of space as there's a brick wall behind the pump and I believe (?) you're supposed to leave 3" of room too. But I guess I'll need to get everything in hand to measure first.
NO! Do not use a solvent on the plastic. It will probably come off by tapping on it or sanding. It really doesn't stick all that well, especially after a few years.
Is your equipment far above the pool? If not, the check valve isn't really needed and you could cut the pipe flush with the 3-way valve next in line, install a 1.5" pipe extender into the pipe in the valve and go from there. It would give you a lot more room. A 1.5" coupler and your good. The Calimar 1.5HP VSP has 1.5" ports. Get 1.5" High-Temp unions for the install. They seal with an O ring, not Teflon tape.
shopping
shopping
Phew, thanks! I'll try to remove the epoxy by tapping and sanding.
The equipment pad is indeed high above the pool, maybe like 6 ft or so. That said, I've never been able to get the pump to prime by itself, so I don't know if the check valves are helping enough anyway. Not sure if the problem was with the pump lid or the epoxy connection or if maybe the lines are just too high and far away from the pool.
Sorry to be so helpless, but do you have any recommendations for high-temp 1.5" unions that will work for the pump? I looked through some threads here and on Amazon but I'm only seeing 2" unions. I assume the unions come with the O-rings?
This one, maybe? Link
Edit: Hmm, any concern with it being listed as NPT instead of MIP? There's also this Hayward one.
Not sure the first one is high-temp, Hayward definitely is not. NPT (National Pipe Thread) and MIP (Male Iron Pipe) are the same. However, high-temp unions are neither, but use a thread that will tighten into a NPT port and then seal with an O ring. NPT and MIP threads are tapered to seal using the threads and sealant. I've always used some Teflon tape on the threads, but that is just my way of being cautious.
High-temp unions cost a bit more but are well worth the expense. Newdude's recommendation is about the best price you will find.
Reactions: nostaljake
@1poolman1 @Newdude
Thank you sirs!
This is probably a dumb question, but I received the pump today and there's a sticker on it that says "this pump must be installed with a two, multi, or variable speed pump motor control".
Am I misunderstanding something, or don't these pumps have a control system built right into them? Is the Calimar going to work on my old single-speed electric setup, which is connected to an intermatic timer? Or would I need a whole new set of electrical equipment?
To the best of my knowledge, it just needs to be wired to the appropriate electric with a timer if 24/7 operation isn't it the plans. Both of my pumps were hard wired straight to the pool panel breaker with 24/7 in mind, but I'll defer to @1poolman1 who has installed every pump he has ever installed more than me. :ROFLMAO:
Thanks! I'm planning to run it 24/7. Just want to be sure it doesn't need some special wiring or something that I don't have before I get started. I don't understand electrical stuff at all 😕😅
Show us some pics of what you got so we are all on the same page with what you are installing.
That is a strange sticker and does not make a lot of sense what they are expecting you to do.
Did the pump come with a printed Installation Manual?
