Ferretbone that would be awesome if he could. I’m not sure if OP can get it around the bends or not. It’s also really dark.
I think what has thrown me off is OP said return “D” goes right which throws a wrench in my theory. I certainly thought it would go left and be T off under waterfall. It was also mentioned “D” is strongest return. “A” being the second strongest “B” and “C” being least. So pinch may actually be before it was T off. I’m not sure what draining it below returns would result. But if he does he can open that return valve and try fishing through to the waterfall. At this point I would focus most of my attention under the waterfall and see if anymore of that pipe can be exposed. After rereading post he did mention some of the rigid was replaced with flex to fix leak so I am not entirely sure if pvc under footer is flex. But do believe the source of his problem is under footer.
