- Aug 19, 2017
- 128
- Plaster
- Hayward Aqua Rite (T-15)
For those of you in the Houston area or other areas dealing with high amounts of pollen currently..... what if anything are you doing about it? Is it just something I will have to deal with every spring around here?
This is our first spring with the pool and WOW I've never noticed how bad it is before. We currently have no trees in our back yard but there are lots of oak trees nearby and all around our neighborhood. I'm manually skimming twice a day (3 x on weekends) and going through 2-3 hair nets in the skimmer each day packed to the rim full of oak buds. Some mornings my pool looks like you could almost walk across it there is so much of the stuff on the surface. When does it end and is there an easier way??
Also, for the first time today I had a CC reading that wasn't zero. It was 0.5. Is it fair to assume all the pollen would cause this?
These are the latest readings:
FC 3.5
CC 0.5
pH 7.8 (just added MA after the test)
TA 90
CH 300
CYA 80
temp 78 (warmest yet!!!
I know the FC is too low. I have been working on getting the SWG dialed in to maintain stable FC but am not quite there yet. I just increased the output% again after today's test and supplemented with bleach as I'm trying to keep FC above 4 at all times. I had been running at 50% output for 5 hrs a day but that obviously still wasn't enough.
FC 3.5
CC 0.5
TA 90
CH 300
CYA 80
