Last summer my AC decided when it got too hot to go on strike due to unsafe working conditions. It has been fired, and now I am interviewing replacements.
Last summer when this all went down, i stumbled upon the Hotspot FPH heat reclaiming devise and was intrigued. I have since read through the big eight page thread here and am intrigued more than ever.
I live in a brick home with little shade on the south side of the house that is serviced by a 40 year old 4ton AC that is dying. One of the local HVAC contractors did a manual J load calculation for my house and my theoretical cooling load is 6.5 tons, but said my duct work is only large enough to handle 4tons. That came as no surprise considering my AC seems like it goes flat out 24/7 from mid-June until the end of August. It actually starts up in May and runs through September, so it puts on a fair number of hours every year.
My pool is an in ground 18x36 gunite pool on the east side of the house, so for a good portion of the day it is actually in full shade cast by the house. I have a big natural gas heater, but to maintain the temperature in the mid-80s, it has to run a lot. I figure last year, I used 100 therms for July and then another 100 in August to keep it warm just for the weekends. Without heat, the equalization temp is somewhere in the mid-70s. Yes, I have a cover...a dark blue automatic one.
i figure, i am a good candidate for one of these gizmos, and the time is right considering I have to rip out all the AC anyway.
So, I have some questions and thoughts:
Is the conventional wisdom that it would void the warranty of a new AC, despite what hotspot says under their FAQ? Have any of you had any problems where it has caused the AC to have a problem?
Hotspot says it will make the AC work more efficiently. Have any of you been able to see this? Is it enough to offset the power needed by the pump running all the time to keep water circulating?
Hotspot also says for every 12,000BTU of cooling capacity, there is actually 15,000BTU of energy out there being used. Has anyone done any sort of math to see how much they think they are harvesting?
Any other tips or things to think about?
Thanks-
Thanks-
