Plettschner
I just Googled "spa moving dolly". Very interesting. Had not heard of these before.
Yep couple more hours and we will be home. Hasn’t been too bad. Moving the tub on th trailer wasn’t bad at all. It was on a short deck that was about trailer height and we maneuvered the trailer as close as possible. Used a cart to prop the tub up enough to get a block of wood underneath a of it and then 2 of us lifted it up above the trailer height the other two pushed it on and we were loaded. Propped it up and slid a 4x4 under each side and then packed it upWoot Woot, getting closer all the time!!
Hot tub party at G's place!
Glad your adventure went well. Let us know if you have any questions.
If you have a large diameter hose you can just siphon, I use a hose from my pool vac I no longer use, takes no time at all..All wiped down And the fill begins. Checking everything for leaks etc as we go.
ahhsome going in once full. I know it’s going to gross me out. Sadly no sump pump available so will have to do gravity drain unfortunately so this will take longer than normal. Sump pump ordered from Amazon today so will have it for the future.
Ehh just a regular hose to attach to the drain built into the tubIf you have a large diameter hose you can just siphon, I use a hose from my pool vac I no longer use, takes no time at all..
No pool or pool vac anymoreUse your pool vacuum hose.
Put one end in the hot tub and fill the vacuum hose with water using a garden hose and then drop the other end in the yard and the siphon will begin.
But, that's how I did it the first time!Or, you can wait for three hours watching the hot tub drain through a tiny 3/4' garden hose.
