Hello,
I have had a pool for about 10 years and been using the Taylor test kit (K-2006) for a majority of those years. I feel quite versed in how it works and have a really good process setup with my pool. Though, I recently got a SWG hot tub that is about 450 gal and I have been having a really hard time with the PH test in the Taylor test kit.
When I fill the hot tub from the tap and balance the water, everything is great. I rarely have to add chems to balance the water. My hardness is a bit low but still within range. Though as soon as the water is up to operating temperature 102, the PH goes through the roof. When I check with the strips everything looks fine. I then go about the process of battling the PH/ALK relationship trying to lower one without destroying the other. Once I finally get this to a place that fits within both ranges, the strip now report a PH of under 7(I think because the strip are a bit hard to read).
All of the other tests are spot on, it is just the PH test that is causing me issues. Does anyone know if I need to test the hot tub differently using this test kit?
