Hello,
New to the above ground pool thing. Had the pool installed late last year.
Its an above ground 12x24 The pump is a 2 speed or stage pump. Can run on low or high.
The issue Im having is whenever the pump runs on high it keep blowing the hose off where it is connected on the egress of the cartridge filter.
The fitting is a tapered fitting that really is not holding.. Looks like this - tapered fitting
I have been running the pump on low for a good 10hrs a day... but it just does not seem to get the pool clean as if the pump was running on high.
I was thinking of getting one of these - fitting with hose barb
Has anyone had this issue and would this type of fitting work?
Any information would be helpful.
Thanks!
Thanks!
