Horse pool
The green thing in the yard is a pop up emitter drain - not sure if it’s connected to the pool. You may have an overflow pipe either in the pool wall or inside of one of the skimmers that leads to this.
They sell prefilters (sometimes called cyclones) in most residential pools they are unnecessary but I can see that being helpful in your case.
I too imagine that the red valve goes to the main drain(s)
You’re right to be concerned about a gator 🐊 & polio lol 😂
First order of business is a large sand filter with an mpv so you can vac to waste and start filtering. Without this you’re simply in a holding pattern.
$400/$600 can get you one at various places like doheny’s, inyo pools or even amazon.
You can add a prefilter later, and a swcg if you decide
Reactions: HermanTX
Waterco’s award winning MultiCyclone is a brilliant pre-filtration device that works on the basis of centrifugal water filtration and is designed with no moving parts and no filter media to clean or replace.
Reactions: Mdragger88
I am not frail, but keep in mind I have spent 2 days fighting a stuck driveline on my pto on my tractor . Why you ask? Let me tell you, lol. Someone bent my rotary cutter parked it and never said a word . Ugh ! After this 2 day fight ,I'm pretty tired of it , and might accept defeat ! Lol
I'm kind of handy . Yet not strong like a man. I can saw pvc and put glue . My horses like to break pipes . So as time goes on ,I improve . Lol
I'm thinking I'll try it myself . As long as i understand what is happening . I'm prepared for a cost of $2k .
As far as a pool boy . I have some expectations and requirements . Must work shirtless and have a sense of humor . It's not against the fiber of my being to watch a pool boy work ! I can do possibly $2700 . If he does it.
As far as a backhoe . I'd love a super m with the joystick and clamshell. Except my horses are afraid if I get one ,they will come up missing . Especially when they break a pipe ! Lol
That being said would a 24 inch sand filter be enough ? Will my pump be ok with that size ? Or does someone have a link to a filter that will work with my pump and handle the horse gunk they leave behind.
@Arowdy1
One that holds 250# - 300# of sand (24”-27”) should do ok & be fine with your pump.
Much bigger than that and you’re looking at a pretty good jump in price. If you can swing that its great but not detrimental if you cannot.
The deal is that the bigger the filter the less often you need to clean/backwash it.
For reference I have a 26k gallon pool and a 22” 250# sand filter- i only need to backwash a handful of times per season.
I likely don’t have the debris load that you will experience but you will just need to backwash more frequently than me. Get the largest one you can afford. As we mentioned above you can add a prefilter later if you determine you need one to help keep the filter cleaner.
Most sand filters you find when searching will have an mvp (multi port valve) on them already.
Its the handle on the top that you select the mode you want to be in (filter, backwash, waste, recirculate)
Be sure to purchase #20 silica pool filter sand for it
- i would advise against using an alternative filter media type especially in your situation.
I, too, love the idea of a centrifugal pre-filter. No idea how it will treat the hair, but it makes all the sense in the world for heavy dirt.
See if you can plumb the filter so that you have a run (2ft) of straight pipe up off the ground on the output side before you connect to your pool returns (the pipe currently on the output side of your pump). You’ll be glad to have it when you get to step #672, installing a salt water generator.
I think I know your driver… just made this same repair for my dad. Apparently he left our place and went to yours. There’s a good shop in Houston that can straighten that shaft. Give me a few days to remember the name.
I'm thinking of buying this filter . Almost did then I thought maybe I should check the size of my plumbing ! Lol Since we are currently under a t storm . I'll wait to look . Lol Screenshot_20250502_160224_Chrome.jpg
I read how to install it . I'm pretty sure I can do that .
Am I in the right area for a filter ? Will this one work ok ?
Thanks
I'm ordering the 2 inch one . Glad I checked ! What kind of sand ?
Also I'm noticing I have more jets from pump into pool that I do not see any water movement thru them. Please tell me that's not hard to fix . There are several that don't appear to work .
High-Rate Sand: No. 20 Silica Sand (0.45 mm–0.55 mm)
Pentair uses US Silica Mystic White II sand for all of their testing. It may not be readily available at Ace/Home Depot though. In general, we recommend getting your pool sand from a pool supply store and not a hardware store as they are far more likely to stand behind what they sell than a big box store.
Be aware that members have had issues with Quiikrete Pool Sand. Members find that Quikrete Pool Sand is too fine and perceptibly heterogenous (i.e., not filtered to #20 specifically). It does not filter well and tends to blow back into the pool. A search in the Forum can provide more information about the issues.
Swimming Pool Sand filters generally use #20 silica sand which is approximately .40 to .55 mm.
If the slits in the laterals are a little bit large and the sand is a little bit small, then you can get some sand passing through the laterals.
MYSTIC WHITE II filter sand has three effective sizes, 0.49 mm, 0.65 mm or 0.80 mm.
MYSTIC WHITE® II 0.49
MYSTIC WHITE® II 0.65
MYSTIC WHITE® II 0.80
Depends on the way your pool returns are piped.
First thing is to look into each jet and see if it is clogged.
In addition to what Allen posted, I note you have only 1 return pipe originating from your pump with no visible manifold. Likely the returns are plumbed in series vs individual runs back to the pump. Consequently the returns furthest from the pump may flow little if at all. If you check the returns for clogs as Allen suggested and none are present, you can likely increase flow if needed by installing return “eyeballs” with a smaller diameter outlet in the closest returns to the pump ( or those returns that are flowing the most now) to restrict flow and provide more flow to the farther returns (or those that are flowing less).
Good luck with your pool! We use our 20 x 40 SuperPool for dogs. We've found it works best to rinse the dogs before as well as after they're in the pool, be proactive with the chlorine, and be ready to clean the socks on the skimmers frequently if long-coated dogs are in the pool (show Goldens are the worst!). We use a robot vacuum/scrubber that climbs the sides as well as brushing it down once a week as well as a manual cordless stick vacuum. However, our pool is only 4' deep, so we can literally stand in it and manually vacuum the large blobs of hair or dirt to help out the robot.
It is a lot of work but we have enjoyed it, as have our and others' dogs
Th
Is pool is deep ! I still have not seen the bottom but when I scrub I'm at the end of the pole .
Update on filter . Ugh . I bought one on the 5th . Was supposed to be delivered on 7th . Never showed up but shipping vo said delivered . What a nightmare . They would not refund or replace . So I called shipper and found out they returned to sender. No reason given. So got the ok on refund . 10 more days for money come back to me . So back to shopping . I have 400 pounds of the white sand stuff. Although that filter only requires 350 pounds . They sent me an extra one because one was lost in shipping then showed up yesterday lol . It is back to a polio pit . Lol I bought home depot about out of 2 inch fittings . So I have ability to make a maze if needed . 2 turtles living in the pool . I can't catch them. They refuse to leave .
Are you trying a different vendor to purchase from? Hope the price stays the same.
