Is the 31.45 muriatic acid at home depot the same as the 31.45 radio on poolmath? Was not sure because it had baume. Thanks!
Curious as to what brand you found that has the 31.45%?
I haven't been able to find that strength at any of the local Home Depots around me.
HDX 1 Gal. Muriatic Acid Balancer (2-Pack) 10031HDX - The Home Depot
HDX 1 Gal. Muriatic Acid (2-Pack) is a powerful pH reducer for your swimming pool. It comes ready to use, with no pre-mixing required. This fast-working chemical helps prevent scaling caused by calcium-basedwww.homedepot.com
Oh wow, yeah the local stuff in California is only 14.5%. Bummer. What is the price on that one?
When I search for it, it says it's not available around the 100 miles.
HDX 1 Gal. Swimming Pool Muriatic Acid Balancer (2-Pack) 10014HDX - The Home Depot
Clarify pool water and balance pH levels with this muriatic acid balancer. Made for all pool sizes, it's ready-to-use and lowers pH instantly. It comes with two 1 Gal. containers for convenience.www.homedepot.com
That's the weak stuff I have access to.
12.98 for 2 gallons of the 31.45%.
Your 14.5% is almost the same price.
Ajw22-
I'm surprise. My HD sells it for $9.98 per gallon. You getting it 2 gallons for $12.98 is a steal.
I was paying $9.98 at HD for 2 gallons of 14.5 acid. Started buying Hasa brand (31.45) at Leslie's for $16.99. Since it is more than double the strength, I use less than half the amount which results in a significant savings.I get it at Lowes and I'm in the san diego area. 31.45. About $12
yup, my local Ace has the 31.45% and sells them in a box of four 1 gallon containers for around $28.Ace Hardware usually has the strong stuff.
