- May 24, 2020
- 8
- Vinyl
- Pentair Intellichlor IC-40
Hello,
My pump is about four years old, and it started leaking from the threads on the pump outlet and the filter inlet. They used regular PVC connections. I replaced the connections with high-temperature unions. The filter side is fine, but the pump outlet is spraying from the threads in the pump when I increase the flow for cleaning. I tightened the union by hand with a good amount of force. What would you recommend? I know they don't recommend using a thread sealant but I don't want to over tighten the union going in the pump. Any help is appreciated.
LJ
LJ
