(specs in signature)
11,000 Gallon SW pool, barely used so far this summer because I've been getting work done in the yard for the past 2-3 weeks. Solar cover has been on it the whole time. Still not that hot here in NY so not much swimming. I am brand spankin' new at pools so everything I've learned has been on this site over the past 48-72 hours. Amazing resource, I'm so glad I found it.
PH - 7.6
FC - 4.5
CYA - 0
TA - 200
Salt - ~3500
CH - 200
Using the PoolMath app it says in order to lower my TA I have to lower my PH to about 7-7.2 and then aerate. My plan is to use muriatic acid to lower the PH but will adding CYA also lower the PH even more (I'm gonna have to use a ton of CYA)? Should I conquer these one at a time?
PH - 7.6
FC - 4.5
CYA - 0
TA - 200
Salt - ~3500
CH - 200
