My pool has recently gotten an extremely high level of phosphates and cyanuric acid. My question is will sodium carbonate peroxyhydrate reduce these levels and the pool still be safe to swim in?
Need a full set of test results and description of your pool and equipment (see my sig as an example). Generally, nothing you add will fix too much cyanuric acid. Not sure phosphates really matter if you maintain everything else. Orenda PR1000 will help with phosphates. Draining some water will help with cya.
