I connected my filter about a week ago. Last Monday the pool exploded with algae. I went ahead & added a couple of gallons of chlorine & started skimming all the algae off the top. I also gave the pool of couple of good vacuuming's. Now the what is a lot cleaner but is extremely cloudy. Note: I not did not cover my pool for the winter as we get really high winds which will wreck both the cover & pool.
Test Results Today
TA - 100
PH - over 8.0
FC - 3
CH - 250 (On private well with hard water)
CYA - around 40 (Used test strip. Ran out of testing solution.)
What is the easiest way to get the PH down? The calculator says to add 34 oz's of muriatic acid. I also have 5 pounds of pH lower that the previous owner left.
Should I worry abut increasing the TA for my above ground vinyl pool?
Test Results Today
TA - 100
PH - over 8.0
FC - 3
