Hi everyone,
My pool cover came off three weeks ago, but couldn’t run the pump because I had to replace the motor. As a result, my pool is a green swamp. I have been trying to balance the pool so that I can start the SLAM process. My PH has been up through the roof. I have tried to adjust it with no results. So far I have been through 2 gallons of Muriatic Acid and 6 pounds of dry acid to no avail. Before adjusting the PH I adjusted my alkalinity from 50 to 90. In the process of trying to bring my PH down, My TA went back down to 50 again, but nothing happened with PH.
I’m afraid I won’t be successful using SLAM method without first managing the PH.
This is frustrating. I don’t know how to proceed. 2 gallons of MA and 6 pounds of dry acid and I’m still back to square one. Any help is appreciated.
