I see...so even if I lower the FC with a chlorine neutralizer, would that allow me to get an accurate pH test result? But lowering the FC below 15 would also mean I run into sterility issues, correct?pH test is invalid with FC above 10 ppm.
Yes, I meant that I was overdue for draining since CYA has been building up over the whole time. Obviously I’ll need to keep tabs on my CYA level in the future, but essentially I will always need to at least partially drain every once in a while to keep CYA from getting to high? Or should I alternate chlorine tabs with liquid chlorine to reduce the amount of stabilizer being left behind by the tabs?The water does not get old like you implied and require drainingsThe only reasons to drain are if you let the CYA get too high, like you have, or if the CH gets very high.
Your previous post was correct, which is one reason we do not recommend having the CYA that high
That statement is correct. Use liquid chlorine for daily maintenance when you are home. When you leave for more than a couple days use trichlor tablets in a floating dispenser. Maintain your FC based on your CYA level.Or should I alternate chlorine tabs with liquid chlorine to reduce the amount of stabilizer being left behind by the tabs?
