So I apologize for the upcoming long post. I re-read the entire thread from day 1 and all the articles including the slam process. I have a lot of questions but I want to focus on the slam and the algae.
I've never done the slam so here we go:
- My test shows CYA of 60, a PH of 7 5 and CC of 1ppm => seems like I meet the starting criterias of the slam
- The chart for a CYA of 60 and non salt pool shows 24, so my goal is to get to an FC of 24 until I am done with slam
- I have questions about the calculator but from what I could come up with, in order to get to 24 FC I need 3.6 gal of LC at 10%.
If anything above is incorrect please let me know. Here are my questions:
- To raise my FC to 24, does it matter what is my current FC or do I just add 3.6 gal of LC?
- How much Chlorine should I buy, at 3.6 gal to get it to 24, should I buy 10 gal or so for the slam process at least as a start?
- During slam can one swim? (Had to ask pool looks pretty good but I know I am not done, kids are eager to get back in)
- During slam can I get in the pool (physically) to brush? Corners, light and stairs are not easy to clean with the pole.
- I don't know if my CC level test is accurate, the liquid barely changed to an extremely light pink after the 5 drops of R-0003. Is this normal/common?
- What does increase the CYA? By adding so much FC would that increase the CYA and therefore increase the slam FC level needed?
- When I am done with slam, can the CYA be lowered from 60 to 40 in order to have a lower FC need to maintain?
- Calculator doesn't have a pebble tec option, what should I pick and is my 3.6gal of 10%LC accurate to get to the 24FC?
Thank you all and
@mknauss for all your help.
