The first picture is 60.
Dirk,
This is by far the most frustrating test of the bunch. I am thinking of that slider, as well, but I don't know if it'll resolve the main issue because the test's endpoint isn't exactly clear. In my shaded pictures, the 60 CYA is not quite a dot but it's also not white like a cotton ball. I assume the whole rigmarole of where/how to stand and hold the tube is simply to increase contrast so the endpoint is more clear.
The problem with Taylor's example is that I can barely make out the dot in the last photo! Or I'm just imagining it. I really don't want to have to do a double blind CYA test on my darn pool
OK, so this is not TFP sanctioned, at all. Just my thinking about it. So Mod's can delete, no problem.
I don't have any confidence in the outside shade test instructions. It's not reproducible or consistent, and I think that's important for all the tests. I also believe that the CYA test has the largest margin of error (I got that from Taylor direct). Though it's not clear if that is so because of the chemistry involved, the subjectivity involved, or both. Doesn't matter. It's bad either way.
So what I'm attempting to do for myself, is to establish a very consistent and reproducible test procedure. For
me. For
my pool. So that means indoors, same lighting, no glancing, etc. Maybe using that slider gizmo, because half the battle is squirting a little test juice at a time. Total pain.
To account for the possibility that my results might not match TFP's, or even Taylor's, I'm thinking this: it doesn't matter. My supposition is: I will eventually learn what number my foggy water is telling me. Doesn't really matter in relationship to someone else's test result, or even the CYA chart. (OK, this is where they might want to edit me!) I'll glean a number, but it'll be a consistent number. And I'll use the TFP FC/CYA chart as the starting point, and dose my pool accordingly. Then I'll track the result. If I'm burning through FC more than I think I should, I'll adjust. And if my FC seems to be locked up more than it should be, I'll adjust the other way. Eventually, I'll know what to do about CYA based on how I view my dot, under my light, and not anything else. Dot disappears at W, add X pounds of CYA. Dot disappears at Y, drain Z amount of water. It's a vague concept, for sure. And a bit hard to explain, but it's clear in my head (though not clear yet if I can make it work, or how long it'll take). I think this is kind'a a variation of the double-blind you refer to, isn't it?
I just know there's got to be a better way than relying on a shadow from the sun, which is technically different, even under ideal conditions, 365 days out of every year! Certainly where my waist is seems to be a moving target as well. Not sure what the problem is there!!
If I figure it out, you all will be the first to know!!
