With those numbers, the chlorine will RAPIDLY deplete with 0 CYA.......leave it alone.
If those numbers are correct, I suggest you add 40 ppm CYA immediately and allow your chlorine to deplete down to around 5 ppm or so.
Then, test your CYA and add enough to get to 50 ppm CYA and maintain your FC about 4-6 ppm.
