We had our pool resurfaced/new sand filter about 2 years ago.
i haven’t kept up with any chemicals over the winter, and just started getting it ready for spring. The surface had a couple minor algae spots, so after a brush down/backwash i shocked the pool with 2 gallons of Hasa Sani-Clor. Jug says 12.5% Sodium Hypochlorite and 87.5% other ingredients. I completed another backwash
I tested the water with a TF100 kit, and After 3 days, the chlorine level isn’t dropping.
Water Results are as follows:
FC = 43
CH = 525
TA = 100
CYA = 120-ish+
ran out of red phenol to test the PH.
The water doesn’t look bad, but does have a very slight haze.
not sure why the CYA is so high after 2 years? Do i need to drain and refill?
FC = 43
CH = 525
TA = 100
CYA = 120-ish+
