- Jul 21, 2013
- 65,575
- Plaster
- Pentair Intellichlor IC-60
Ichlor 30 and it’s about a 16k gallon pool.
I have it around 10 when it’s running. The massive cloudiness has happened since adding DE to skimmer because I now see it around light in pool at night as well in addition to bubbles
You have no automation to reduce the SWG generation when in spa mode.
With your SWG % generation set for your pool, when it is generating into the spa it is generating a lot into a smaller body of water.
Next time you are in the spa turn the SWG down to 0 and see if you no longer see the cloudiness.
Remember to turn the SWG back to its pool setting when you are done with the spa.
