More info:
www.troublefreepool.com
Again, interesting. I question some of the points raised by the articles.
Ozone:
1) Whilst pools may be hydraulically inefficient, it is untrue to say that there is no amount of cycles that will have all the water seen by the filter (et al). If we allow an infinite number of cycles, eventually all the water will be “seen” (99.999… = 100). In practice the number is far less than infinity. Nothing is 100% effective (in theory).
2) I am not sure what is meant by a “low Henry’s law constant”. The HLC for ozone is actually relatively generous (higher than oxygen or nitrogen). I also think there may be some confusion about the use of the term. Henry’s law relates the solubility of a gas to its vapor pressure. Henry’s law says nothing about the solubility of a gas itself, but rather how it changes with the pressure applied (hence, ozone becomes proportionally more soluable when pressure is applied than the aforementioned oxygen or nitrogen). It is interesting to note that ozone is quite soluble in water (more so than oxygen because of its polarity).
3) Ozone can get to some of the “nasties” that have accumulated chlorine resistance (C. Parvum comes to mind). I assume most of the bubbles are either excess ozone (as the water would’ve been saturated) or the O2 gas that would’ve been produced by ozone’s post-oxidation decomposition.
4) In theory you could test for ozonation by testing the oxygen content in your water (in much the same way total chlorine is related to free chlorine). Directly, one could use the oxidation reaction of nitric oxide (readily available and conveniently a chemiluminescent reaction). In my view, ozone works the same way as sodium bicarbonate, it does it’s work quietly and then is released into the ether.
Mineral cartridge:
1) Does the silver not provide anti-microbial effects? As I understand it, silver works by damaging the proteins around bacteria’s DNA which eventually leads to DNA damage or death. These principles hold broadly the same in bacteria and viruses and is taken advantage of by several topical anti-septics (See Silver Sulfadiazine). Is there some threat of build up in a pool system?
2) Does the risk of algae bloom not outweigh the risk of copper staining. Many species of algae are now becoming resistant to pure chlorine and the only algaecides that are effect against them are copper based (or quaternary ammonia, which I am reluctant to use in a system predicated on calcium hypochlorite). If you have no issues with staining, as I do, why not get to copper sooner rather than later?
Thanks in advance.
