she forgot to turn off water
So for 4 days the Pool was filling and running over. Uggg.. anyways in the 108 degree temp everything dried up pretty good now and water level was good after 2 days. But, I was worried about chem issues and did a CYA test, it was @ zero which normally it’s at 60ish, so I added the HTH? powder through sock in skimmer (4lbs) and I helped all of it dissolved in a few hours by squeezing sock. I guess the water running for 4 days was diluting the whole pool and made everything change, obviously.
Now, I thought it takes a about 6-7 days to actually get a correct reading after adding and now it’s back to 60.
So my question is, after 2 days is my reading correct ? Label said 4lbs would bring it up to 50ish give or take for my size pool.
2. Did running that much CYA through the skimmer that fast hurt anything ?
I used the TF-100 directions on testing
Thanks
EDIT. Normally, I would be able to keep an eye on the pool but heading to Argentina in 36 hours and was wondering
Thanks
