All,
Can't believe I am starting my own "build" thread, and not sure if I am more terrified or excited
Have come across so many helpful tips and pieces of advice in my lurking over recent months, but now hoping for insight specific to my situation. Attached is a lot plan with the initial layout of the yard and pool (North is toward the top of the page). Below are some of the specific items we are looking at, please critique this as much as necessary as nothing has been set in stone yet.
Once I get feedback the next step is going to the engineer to get plans and permits, then contacting Subs.
Plan:
Plan:
- Gilbert, AZ
- 16' x 26' Rectangular - no water feature
- ~11,000 gallons
- 4' to 5' to 4' (floor to mid waterline tile)
- 7' x 7' elevated spa (18") with spillover. (Sit and Spin style, within border of pool to save yard space for pergola/outdoor kitchen)
- 8' x 8' baja - next to spa
- Robot cleaner (no longer planning IFCS based on feedback here)
- Microbrite lights
- Two on the South (long) wall - to face away from the house
- One on the baja step
- One in spa
- Mini Pebble
- JewelScape's Yacht Club Blue
- Waterline tile - TBD
- Coping:
- Travertine vs Limestone
- "Pearlescent" is one option recommended by contractor (Monterrey Tile Company - Shop Pearlescent products today!)
- Same decking to be used for coping, patio overlay, and pergola pad/outdoor kitchen
- *Will be placed on a pad along the West wall, behind a pergola
- Pentair Intellicenter i8PS combo with VS pump, 2 valve actuators, and IC40 SWG
- Pentair CCP420 Cartridge filter
- Jandy style valves (no ball valves)
- 2 skimmers - separate returns
- One on the East (short) wall near the NE corner (d/t wind direction)
- One on the South (long) wall (closest to the patio)
- Auto-fill connected to water softener in the garage (West wall near access door)
- Heater - HELP!
- Should the travertine/linestone be placed in the equipment pad area also? Or just use concrete?
- Best HP for pump? (I am of the assumption this will power both the pool and spa on the same pump?)
- Return lines okay at 2", but all supply lines should be 2.5" minimum?
- Best Heater for my setup? Natural gas stubout available at back of the house, as well as at gas meter
- Chiller now or just have plumbed to add later? How much room do I need to leave/account for this at the pad?
- Thinking a Glacier brand. Not sure if GPC25 is sufficient for my pool size, or if I really need the GPC210. (see attachment for specs)
- Baja 12" to waterline?
- Should I add steps off the baja into the pool? Or steps elsewhere? I don't want to cut into the baja with steps. But, 18" baja down to 4' is going to be a big drop.
- Do I need the Pentair 420 filter, or is the 320 model sufficient? (see attachment for specs)
