You need to
SLAM Process to clear that cloudiness. And when you're doing that, you have your SWG shut off. So you don't care what the salt level is right now. It[s going to be totally different by the time you're done, anyway, with all the bleach you'll add (it leaves salt behind) and the backwashing after you clog the filter a few times.
First thing you do is add enough bleach to get to 10 FC. Brush it around good with the pump on so it's mixed well. In 15 minutes, retest FC & CC. That will tell us if you have an ammonia problem. If you do, you might want to replace water, so no point doing anything else until that is resolved one way or the other. So post the results and someone will be along to take you to the next step.
