Hi and welcome, Bbaggett.
First, breathe. If you’re ready to take control of your pool, we’ve got you. Everyone here is more than happy to teach you how to clear up your algae and then take care of your pool in the easiest, most cost effective way possible.
First things first. You need a good test kit, capable of measuring CYA and chlorine above 10ppm. The two kits we recommend for that are the Taylor K2006-C, or the TFTestkits
TF100 (which is a better value). The required tests typically can’t be found in stores so you’re stuck ordering online.
Depending upon your CYA level, you might need to do a partial drain/refill to get that down to a reasonable level. But we need to find out your CYA level first. Then, you’re going to need to complete a
SLAM Process.
So here’s your homework:
1. Get a test kit ordered, so you can have that in a few days.
2. While waiting, add a gallon of liquid chlorine (either liquid “pool shock” — Pool Essentials from Walmart or HDX from Home Depot are popular choices — or plain household bleach, no “low splash” or scents or other additives) to the pool each day. That should keep things from getting worse.
3. Read through
ABCs of Pool Water Chemistry and
SLAM Process. That will give you some insight into what we’re working toward.
4. Once you get your test kit, do all the tests and post up your results here. From there, we’ll advise what to do next!
