Hi. I finished rebuilding my 16x32x48 oval a little over a month ago. I built the pool on a built-up, compacted gravel screening base. I covered the base with rigid foam insulation, and gorilla taped all of the seams. The foam coving is gorilla taped to the wall and also the foam base. Our liner is a beaded liner, hanging in a bead receiver track.
The problem we've run in to is water between the liner and the base. When we first started using it, the liner was pristine and wrinkle free. Over the course of the last month, we've noticed wrinkles in the bottom that are easy to move around, and slide on the base underneath. I'm pretty certain that water that splashes over the bead on the liner has found it's way down under the liner. Some of the receiver tracks have a gap of ~1/8" between them, and I presume it's weeping down through those to below the liner.
My problem is that the foam underneath is impermeable, and over time, the problem is only going to get worse - as it has continued to get worse over the last month. I'm super happy with the foam base, but we wouldn't have this problem with sand (or an overlap liner).
Does anyone have any ideas on how to get this water out? Once we remove it, I'll probably go around the track with a bead of silicon to seal it off.
