Hello and TIA!
I will add a pic of the wiring. Pool light didn’t work, found “box”, and the pool light has been unwired. I’m assuming it went bad, and they just unwired it. Assuming is the huge word, as I have no idea. We bought the house over the winter, and I’m just now SLAMming and starting my detective work. There is one connection in the box that is live, I’m again “assuming” to the gfci outlet. Both this junction box and a gfci outlet are located in a half bath, right by the pool. Gfci outlet works fine, tests and resets fine. What would you do first? Reconnect the wiring and see if maybe just the bulb is out and they didn’t know how to replace the bulb? Assume the entire unit is bad and run a whole new fixture? Last picture shows the light in the pool, the switch on the brick wall attached to the bathroom where the box and gfci is.
