Brand new pool never been used. Finished building and turned over to me 12/29/2018. They prepped the pool with liquid chlorine because I had to wait a month before adding salt - wet edge finish.
Now I have a CL problem. I use the superchlorinator to up my chlorine for 24 hours, and it works - up to CL =5. It then goes to medium setting. But after a day or two, it goes back down to CL= .5 It has been cloudy, cold, and rainy, but the swg is still on 24 /7. Some nights it goes into freeze protect because it is so cold. The water is crystal clear.
22,000 gallons saltwater pool. It is frame by two big live oak trees that have been dropping leaves like crazy into the pool. At one point last month, there was some brown gunk one the sun shelf and the steps. It is no longer present - at least not visibly.
Hayward SWG
TEST KIt is Taylor
FC .5
PH 7.6 with electronic probe
TA 160 (high)
CH 250
CYA .5
salt 3282 with electronic probe
I also double check with test strips.
Does that help?
Adriana
Hayward SWG
TEST KIt is Taylor
FC .5
TA 160 (high)
CH 250
CYA .5
Does that help?
Adriana
