Good to know - I went out and added 2 lbs of conditioner in a sock that I hung in front of the return jet. Yes, at this current time unfortunately Clorox is the only brand of bleach available. Went to Menards the other day to grab their last 3 jugs of 12.5% liquid chlorine, but on the way there, someone came in and bought themYour CYA needs to be a rock solid 30 minimum, even 40 is fine. Then be sure to keep the FC elevated. It's falling much too low and will allow algae to creep into the water. Always refer to the FC/CYA Levels. Is Clorox the only brand of bleach you have available? The Clorox brand has fabric polymers which can disrupt good pool chemistry. Just about any other generic bleach or liquid chlorine will do. But you must keep it higher.
