So I moved into a house with this hot tub about a year and a half ago. From what I know it is a Maui brand, installed in 2007. I've got the chemistry side down pretty well (thanks to this website!), however am pretty clueless when it comes to the mechanical parts.
A few months ago it kept popping the circuit breaker every time that it came on, so I removed the front panel and found the control board, and unplugged things one at a time until it kept working. Turns out it was the "blower" that was the problem. I read that the blower is pretty much optional, so did not worry about replacing it.
Today I took all of the cabinet panels off to paint them, and noticed that the "blower" was actually another pump. The pump that is still working sounds like its on its last leg as well, so I was planning replacing that while I had all of the panels off. I guess now I need to replace both pumps.
I have no idea where to start as far finding replacements. I'm not real picky and not looking to spend a fortune, I figure we'll probably get a new hot tub eventually, but trying to buy a few more years at least. I'm wide open to any suggestions!
The current pump(s) are: Aqua-flo, flo-master XP2e model# 93577375, "CONT. HP"- 3.0/375, " MBHP"- 5.0, Volts 230, amps 12.5/4.3
