Help with quote
DLZ90
4
Sacramento
Hi everyone
If not allowed please let me know to delete this post.
Can I get input on this quote?
Does it look good to go?
They are price matching a competitor by:
Removing the following:
Automation
2nd day of dig time
Matched the undersized heater
Removed UV Ozone
Moved Skimmer and auto fill to house side
  • Design V2 Pricing PDF.pdf
The inline chlorinator using tablets with acid will shorten the life of your pool heater. The tabl;ets will also continuously add CYA to where you have to drain pool water to manage your water chemistry. We don't view using tablet chlorination as long term sustainable and recommend a SWCG for chlorination.
I would never pay 100% of the costs before the pool is fully operational. You should have at least a 10% holdback.
Reactions: kimkats and DLZ90
We are debating between them and sac pool pros. Premier has a life time warranty though?
@1poolman1 is in your area and may have thoughts.
Wondering if those downgrades will be worse off for us in the long run.
Thank you!
I think automation is a must with a VS pump, spa, and heater. automation is the brain that efficiently manages the equipment.
There is no substitute for BTUs. Get a 400K heater over the 266K. Everything will heat twice as quickly.
Thank you!
I couldn’t ethically tell you to pick one over the other but the contract looks typical, that much I can say.
