Hello!
Was hoping to get some guidance on my current situation....I moved into the house in '16, have never had a problem with the pool set-up, aside from changing the salt cell once. So about 2 weeks ago I noticed the motor for my pump making a God awful noise. I figured it was near deaths door, so I went ahead and ordered a replacement from InYoPools, which was noted to be compatible. (PART # UST1102 ). Before the replacement even came, I went outside and noticed that the pump and salt water generator had completely lost power. I figured it was the pump finally kicking the bucket. So I replaced the pump tonight, everything went together great, exactly as the video showed. I turned everything back on, and it ran beautifully, for about 10 minutes or so, then the same thing, everything shut off...
I have 2 questions really, I'm probably going to call in the experts to come take a look, but can you guys think of anything else that could cause this?
Second, in the meantime, any suggestions for circulating the water? I have plenty of bleach, so can manually add that. I have a sump pump I could run a few hours a day, is that even worth it?
