Thank you in advance for any assistance. Please advises whether my plumbing layout is sound or if I may be missing something. I have designed and started building a 15x30' pool with an attached spa. The excavating is done and I am starting the plumbing. Attached are two picture with proposed plumbing layout, taken from the deep-end side of the pool. There is a trench the length of the pool from the drain in spa through the main drain and then to the equipment pad. This trench will include six 2" pvc pipes ; pool drain, skimmer, spa drain , pool return, spa return, spa blower return. The skimmer and drains are all home runs. I haven't seen plumbing laid out like this before but it occurred to me to be an efficient method unless there is some issue I am overlooking.
