"Spa" wasn't in the speed settings. I believed is it the valve set up to swap over to Spa mode?? Maybe its not LOL (was trying to remove the One Touch Spa Mode setting).
I was trying to swap the valves over to run the spa for a bit, while using a higher speed (now called High). I had previously programmed it used the one touch Spa Mode setting but figured it was going to be the same problem as the Clean Mode one touch I was using before.
Thought process was this:
Everyday Start at 7:30am
Everyday run High speed (to skim) from 7:30am-9:30am
Every M and Th - swap the valves over to Spa to allow the spa to filter from 8:15a-8:50a (or anytime really) - I MAY HAVE DONE THIS WRONG. Since there is a "Spa" speed...
Every M - run the air blower to move the water in those lines
Everyday run high speed for the last 45min-1 hour to final skim
Does that make sense?
I've attached speeds.
