- May 3, 2014
- 62,725
- Fiberglass
- Pentair Intellichlor IC-40
The issue is that you are waiting 10 hours to test and replace FC. Test and replace to slam level every 1-2 hours in the beginning, until the loss is smaller. You want to try to maintain slam level and not let it drop so much.This morning my FC was 13.5, I added bleach to 16, and 10 hrs later it’s 1.5
Do you think my CYA is not holding bc of whatever is in the pool is consuming it? With all the sun our pool gets all day I can’t seem to keep FC up (and I’m at work all day) but will have to try something different.Read this. Print it out, read it three times. Link-->SLAM Process
Then slam every hour your are home, even late into the night (if you can). It is unlikely there is anything in your pool consuming CYA. It is likely variability in your testing. Ignore CYA and focus on FC.I’m at work all day
I haven't changed anything with how I test except I have new FAS-DPD powder and reagent from the TFP kit. I started with the new reagent then my powder ran out and I started the new powder. I don't know what else but I tested twice this morning. I will check again when I get home but I fully expect FC to be around 3 or less with the sun we're getting.Something is off with your testing. 4Gallons of bleach would raise FC 13-17.5 depending on strength. Chlorine circulates fine and doesn't "not mix well."
What size sample are you using to test?
Re-test FC with the FAS-dpd. Take your time. Hold the drop bottle vertical, squeeze very slowly and let the drops drop from their own weight, swirl. 10ml sample. Each drop is .5I
