Help with complete equipment replacement and plumbing ID
mas985
15,410
Pleasanton, CA
That is the most common size. It is the threads that you have to match too which may be difficult without knowing the manufacture.
They are the same size as my jets which are Waterways 217-1080 but I can't be sure that is the same as yours.
Mine are about 16 threads per inch. 4 in a 1/4" peak to peak.
Reactions: hockeyrcks9901
hockeyrcks9901
Active member
Sep 26, 2018
26
Palm Harbor, FL
What are your thoughts about there being air bubbles with the eyeballs and jets removed but when they're installed it flows out the intake pipe?
hockeyrcks9901
Active member
Sep 26, 2018
26
Palm Harbor, FL
So it took awhile, had a wedding to attend and we were having the floors replaced in our house but I finally got around to checking the new jets versus the old. And the new jets are a bit bigger than what was installed.
mas985
15,410
Pleasanton, CA
You might try calling Inyo and seeing if they can help find your jets. The most important identifiers is the thread diameter and pitch plus the nozzle orifice diameter.
