No markings. Approx 3/8"Is there a part number printed on the jet? What is the diameter of the jet orifice (nearest 1/16th)?
What are your thoughts about there being air bubbles with the eyeballs and jets removed but when they're installed it flows out the intake pipe?That is the most common size. It is the threads that you have to match too which may be difficult without knowing the manufacture.
They are the same size as my jets which are Waterways 217-1080 but I can't be sure that is the same as yours.
Mine are about 16 threads per inch. 4 in a 1/4" peak to peak.
Waterway Nozzle Gunite Jet 3/4" White #217-1080 | PartsWarehouse
Waterway Nozzle, Gunite Jet, 3/4", White #217-1080 - Pool Parts and Accessories. Largest Selection, Best Prices, Free Shipping Available at PartsWarehouse.com, Find Any Part in 3 Clicks, Pool & Spa Replacement Partswww.partswarehouse.com
That isn't surprising. The jet nozzles need to be installed to prevent back flow into the air pipe.What are your thoughts about there being air bubbles with the eyeballs and jets removed but when they're installed it flows out the intake pipe?
So it took awhile, had a wedding to attend and we were having the floors replaced in our house but I finally got around to checking the new jets versus the old. And the new jets are a bit bigger than what was installed.That is the most common size. It is the threads that you have to match too which may be difficult without knowing the manufacture.
