- Jun 8, 2019
- 4,576
- Vinyl
- Pentair Intellichlor IC-60
Keep in mind that evaporation and refilling doesn’t lower CYA. You need to pull water from the pool and then refill to do that.
Did you do the diluted CYA test? Full to 7ml mark with pool water, then to 14ml with tap water, shake to mix, squirt down to 7ml in the sink, then do the test as normal with that 7ml sample.
