Hi all,
I came on here researching how to bond my new pool pump and after reading realized i probably have more questions and work to do...
I have an 8' diamater above ground metal frame Intext pool. We put it up and down every summer and fall. I love the pool but hate the cheap pump that comes with it. So i bought and oversized Intex samd filter. Love it and helps to keep the pool sparkling clean.
not surprised when the pump died, i just purchased a new Pentair 1HP pump. Reading over the installation it mentions bonding. Im fairly handy with electricity but never covered this topic.
Sounds like i need to run some 8AWG wire from the lug on the outside of the motor and around all of the metal parts on the frame. Then also to any other metal and electrical equipment within 5 feet (metals fence and gutter).
Do i then need to bury that using a grounding rod?
Also i had my last pump connected to a GFIC outlet. After reading here what else shoild i consider doing to make my pool safe? Should i have a shutoff switch on the GFIC outlet? The outlet is like 2 feet or less from the pool. That sounds too close after reading here.
Anything else i need to do? I have two kids so really concerned avout safety. And freaked out i may not have been operating so safely these past years. So glad i found this site!
Pentair 340104 Dynamo 1HP Single Speed Above Ground Pool Pump without Cord, 115V
Dynamo pumps are an example of excellence in hydraulic engineering for that elusive combination of high efficiency and longevity.
lesliespool.com
